Ryobi 3302/Itek 3985
Emtri
Hey PrintPlanet.
Our company is looking to sell off our Ryobi 3302/Itek 3985.
It was included when we took over the company but have no volume to run it.
Paper Size (Max.) 340 x 450mm (13 3/8 x l7 3/4")
Paper Size (Min.) 90 x 130mm (3 1/2 x 5")
Paper Thickness 0.04-0.3mm (0.0016-0.012")
Printing Area (Max.) 330 x 438mm (13X 17 1/4")
Printing Speed 3,000-10,000 sheets per hour
Plate Size 335 x 485mm (13 3/16 x 9 3/32")
Plate Width (Max.) 352 mm (13 27/32")
Plate Clamp Type Straight edge clamp with plate positioning pins
Blanket Size 330 x 496 x 2.5mm (13 x 19 1/2 x 0.098")
Paper Feed System Universal feeder
Feeder Pile Capacity 440mm (17 5/16")
Feeder Pile System Pre-pile
Paper Delivery System Chain delivery
Delivery Pile Capacity 510mm (20")
Registration System Push guide
Number of Rollers Ink rollers: 16 (form rollers: 3) Water rollers: 5 (form roller: 1) [two sets, one for each unit]
Dampening System Molleton
Gripper Margin 8mm (5/16")
Vertical Image Adjustment (Max.) ±20mm (3/4")
Power Mono-phase 200V 50/60Hz 12.5A, 208V 50/6OHz 12A, 220V 50/60Hz 11.5A or other voltages Three-phase 200V 50/60Hz 8.5A, or other voltages
Wattage 2.5kW
Motor Wattage Main drive: 1.5kW Pump:(mono-phase) 550W,(three-phase) 750W
Dimensions (L x W x H) 2,200 x 965 x 1,560mm (86 3/4 x 38 x 61 1/2")
Net Weight 1,260kg (2,780 lbs.)
If anybody is interested you can contact me here or at [email protected]
Located in Vancouver BC
Looking to get between $500/1000 for it. Machine was in good working condition, but has been sitting for a few years now. Would need some parts to get back into proper condition.
