scope and cip
  • Thread starter Thread starter pam_add
  • Start date Start date
P
pam_add
Guest
dear sirs we have esko scope workflow we are swevice buerue ans our mission to make plates and file for our customers (printers) in past few days i got from one customer who own hidelberg 4c machine .
any one try this any suggest you are welcome .
Re: scope and cip
do you have the ink planner ticket? (produces the CIP3 file)
otherwise it is a payable option, i think
Re: scope and cip
pamela,
you will need your Esko rip to export a CIP 3 PPF file. This is usually an option. the printer will need Prinect Prepress Interface to interpet the PPF file for presetting the ink zone. His Heidelberg Press Console must be of a vintage that is able to read this via a card reader or network. Hope this helps.
Regards,
Mark Tonkovich
Heidelberg USA
Product Manager, CtP & Proofing
Re: scope and cip
yes i have ink planeer ticket but the problem is i don't have any information about this ticket please anyone can give me any info or any pdf explain me or send to my mail add [email protected]
Re: scope and cip
Inkplanner can only work after the 1 bit tiff is created.
so create a ticket the steps of .... expose .. then... inkplanner.
use CIPress to configure the cip file that you need, path, etc.
Re: scope and cip
thanks d-max dor your helpful replay
i try as you told i run cipress setup and after create the required files , i create a workflow ticket to expose to screened file then the i add the ink planner ticket .
the problem is now , i can't make cip3 or ppf file , when i read the ink planner log i see this lines
inkplaneer on flexrip version 6.0
could not retrieve full information from lthe log file even after 10 attempts
so please check the rip log file to see the status of inkplanner
i want use the cip both films and plates i don't where is my mistake in the setup of cipress ? or i must config the dispatcher also ?
Edited by: pamela on Jul 3, 2008 9:41 AM
Edited by: pamela on Jul 3, 2008 9:47 AM
Re: scope and cip
which licenses do i need to have in flexrip 6.0 to work the ink planner ?
