Screen PalteRite 8000II Errors
masfari
Hi All,
i am facing the following error on the CTP Screen PalteRite 8000ii:
  • E4116: Mechanical error Servo status illegal
  • E516C: Mechanical error SVC Error has occurred during drum pointing for lead clamp.
  • E41e2: SVC overcurrent
  • E416f: SVC Error has occurred during drum positioning for balance pin insertion
  • E5170: SVC Error has occurred during drum positioning for balance pin pulling out.
Kindly need your help on this issue, you can email me too you kind help is much appreciated thanks in advance
Was thinking it could be the drum motor and power pack.
On the PTR variant I work on the drum motor has a electrical connector that has power and communication to the power pack. I once had a bad connection. Just unplugged, lubricated and re-plugged it solved my issue. It suggests a power pack as drum may not be rotating
