Screen PTR 8300 Error E517c PH25 sensor illegal.
color_prepress
Last few day it gives this error after it unload the finished imaging plate and start loading the new plate to prepare for imaging.
If I only load 1 plate and not put 1 more for standby into machine, it work ok.
Today even I just put 1 plate and not putting 1 more for standby, it still cannot work and give this same error.
The error something related to it check the drum whether got plate or not before it start loading it into drum and due to something that I dunno the machine/sensor found there is something at there and refuse to load the plate into drum.
Anyone can help on this.?
Clean sensor? clean something that sensor reflect? clean drum area that it check?
Any 8300 service manual and photo for the area to clean?
Is that ok to disable the PH25 so that it can load the plate?
Urgent need help.
Customer need the plate and now machine cannot image due to sensor problem
james_aug
Urgent need help.
what is the error messahe shown
color_prepress
I found out the problem, 1 of the PH25 sensor which model is FSV21R the preset value lower than current value. Raise the preset value more than current value then it can work. Don't know why suddenly the value can out as it had use so many year without problem. Thanks
Besides the lenses on the clamp arm getting dirty they are laser diodes that can lose intensity over time so it is not unusual for the sensors sensitivity to occasionally need adjusting.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
