We run these coin reactive inks a lot and do not see the issues you are experiencing. On very low coverage image areas we have to keep our dampening to the very bare minimum, it seems even more important with this 'invisible' ink. If this issue is happening on both of your presses I guess we can rule out mechanical issues. Is this the first time you have run this type of ink, if not has anything changed since you ran this ink before? different FS,different ink supplier?
Here's some more info on Plate Blinding.
Problem
art or all of image on plate does not take ink.
Plate Blinding - Chemical
Cause:
Fountain solution too acidic
Excessive gum in fountain solution
Plate cleaners and/or scratch removers have dried on plate image
Fountain system contaminated by detergent
Excessive fountain solution in ink
Improperly developed plates; gum adheres to image area
Solution:
Adjust fountain solution to proper pH/conductivity (pH 4.0-4.5)
Re-etch plates and rub up image areas with press ink; replace fountain solution with tap water; if image returns, replace tap water with fountain solution containing less gum
Rinse plate well after cleaning
Thoroughly rinse all washed parts before re-installing in press
Reduce dampener setting to minimum level; consult ink manufacturer Wash plate thoroughly; remake if necessary
