Christopher Wood
I've just started using a Selectset 7000 on my new job. No manual
When we power up the device, it runs about 2 feet of blank film into the cartridge. This only occurs at power-up. I can image some film and cut it, then image some more, and no film but the first set will have that 2 feet of waste, so it's not a matter of minimum material.
Is there any way to suppress or at least reduce the amount of film that the unit feeds at power-up? (Is this a malfunction, even!?)
I've poked through the menus, but they are all icon-driven, and honestly they're not very intuitive icons. And, like I said, no manual
I found the settings for pre- and post-image extra feed, and they are working correctly. I set them way down, then set the back-end feed up a little because it needs extra material at the tail of a run because it always gets exposed to light when it's time to feed the material into the developer. But the 2 feet on power-up is a different matter entirely than the pre- and post-job settings.
Help please! Thnx in advance. And yes, I've been in prepress for 25 years and I'd never heard of this forum before. I can't wait to explore!
