James Cameron and 3-D printing........
The next thing will be the broad adoption of reseparating incoming files to reduce ink usage and optimize images for the press.
best, gordon p
Gordo
Is "ink optimization" actually new or is it just GCR with a new marketing slogan?
[SNIP]
If the printer wants to run with a higher GCR level than defined in the GRACoL profile, then there would be some savings. But how much more GCR can one run before reducing the quality of the image?
Would consistency be another benefit of reseparting files? Reseparating all files would guarantee that all files for all jobs would be in the same print space. This should theoretically result in less press changes between jobs. But is that an actual or merely theoretic benefit?
I can envision that a greater benefit than inter-job consistency would be the inter-image consistency within the same job. Unless the files have undergone late stage separation, extensive colour correcting may cause “separation imbalance” in the images.
Walter
"increase GCR significantly", "reduce ink usage by about 15%" - are your comments relative to GRACoL separated files? I have run tests with a few of the solutions you allude to, set to maximum ink savings and can achieve a mere 3 or 4% reduction.[/quote}
Yes. In fact in the test results conducted in the IPA Roundup: Ink Optimization RoundUP - 2010 Results Report | PrintTools the ink savings actually ranged between a low of 17% to a high of 30% while maintaining the visual appearance of the non optimized image.
Would you agree that the greatest ink savings would be found in the newspaper or printing on uncoated stocks?
Possibly because images received by newspapers are typically separated to GRACoL not SNAP.
Would you expect to see a 15% ink savings for GRACoL separated files for a print run on a #1 coated sheet?
Yes, see the IPA test results.
best, Gordon p
GazKL440 did you used to work for the Detroit News . . . a while back, right next to the back door to the press room was a local bar . . . you could walk in anytime the presses were running and find half the crew there . . . the other half was covering for them in the press room . . .no lie
