Paultheprinter
Hello,
i have suffered with a problem for some time when i finnish backing up say 40,000 sheets coated 130 gsm, the spray from the first side buiilds up on the impression cylinders and l
deposits large flat leaves of powder, these are sometimes 30 -40 mm in diameter and always in non image areas of the sheet. This seems to have got worse recently and is only more apparent on thinner stocks 170 gsm and less. The press is a 2001 SM 74-5 and the spray varn fine coated 1.5 micron. Any help appreciated as i can find a thing
Paul
Paul
