nothernlights
We were having problems using the VARN COATED MEDIUM and VARN REGULAR MEDIUM ( 20 to 40 microns ) spray powder for our machines. Whenever we are use these powders they would clog up our spray powder heads. After switching to VARN Fine ( 10 to 20 microns ) the problem went away but we've observed that we are using a heavy coverage of the powder whenever we are running thicker boards ( 220 GSM and higher ).
Is it common for the MEDIUM powder to get clogged up on the spray powder heads? Is there away to reduce the amount of spray powder for thicker boards if we are using a FINE coated powder?
Also what precautions should we take when we are using spray powder in the press room?
Thanks.
Thanks.
