Can someone please provide some insight into what are some standard dot gain standards when running CTP. I have a DI press and when printing raw data from the rip we print with lots of gain (way more than normal CTP plates). At the rip we include a curve that basically removes all dot gain so in fact making our plates linear. We then add back a curve with the desired amount of gain.
I am running a Xitron rip and initially my rip was setup to simulate SWOP using the SWOP dot gain curve in the rip. I assume this is old SWOP as the gains are quite high.
I understand that when many people put in CTP, out of the box things print pretty good and so I wanted to simulate these standards. I have done extensive searching for info but I have not found a lot. My plan down the road is to possibly go for gracol but in my reading it appears as though you want to start with a press printing to decent standars before you make your adjustments for gray balance. My question is what is this standard?
What is standard dot gain for all 4 colours for :
5%, 25% 50%, 75%, etc.
Based on some reading, does the following appear to be true?
At 50% black gains about 4-5% more than cyan and magenta.
At 50% yellow gains about 2% less than cyan and magenta.
Does cyan gain more than magenta, or magenta more than cyan?
I seem to have problems in highlights and midtones (printing too light) and so I also think the shape of the curve may be important as well in this area.
Any thoughts? Any curves to share?
