Re: Standard Line Screen
John W,
Yes, at midtone, the cyan dot on plate is 5 (%, points, dots, however it's correct to say it) higher than the black dot on plate, and this would show a color difference. However, I don't have a problem with this because although Nexus switched screen angles for black and cyan (on all impo and autotrap workflows), the correct bump curve is being used for each. So angles got swapped, but not bump curves. So black looks correct on press sheet and cyan looks correct on press sheet. The angles being switched has not caused a problem that I know of. This does go to show however how I can set it and forget it (and it change somehow after it is set up correctly). The workflows have the correct angles set up, and the override doesn't work on the angles (it says it's screening one angle and then screens another angle. Maybe if I have a Cyan sep I can choose the Black angle it may give me a Cyan angle). So either Nexus or DotSpy (both from AWS) is lying to me as for as what angle it is. Just another example of me feeling like I'm dealing with some sort of beta software when stuff is set up correctly and then something changes without me telling it to, not working as advertised, etc. I digress.
Don
John W,
Don
