To claude72,
Probably most people are not aware about how the gray level limitation problem was solved. Fuji in particular has made very effective marketing use of that lack of information.
Regarding the dpi/lpi cell size issue. I can illustrate the problem better than I can explain the solution as math is not my strength.
An imagesetter/CtP can only image complete pixels to form the halftone dot. Below is a graphic - on the left, superimposed on the recorder grid, are 5 halftone cells (1,2,3,4,5) with 25 pixels in each cell and with the cells at 90 degrees (the yellow angle). On the right the same cells are angled at 15 degrees (the cyan angle). Note that the cells no longer have 25 whole pixels available in each cell, nor does each cell contain the same number of pixels. (1=14, 2=15, 3=14, 4=15, 5=15). So we've gone from 25 pixels per cell to an average of 14.6 pixels per cell even though both dpi and lpi have remained the same.
