Fuji Xerox DocuColor seems good. What do you think? https://www.fujixerox.com.hk/zh_hk/...on-color-systems/fuji-xerox-docucolor-1450-ga
I can print pretty good. My specialty is cursive hand-writing, though
What model are you using? Thanks.Generally, yes, Xerox makes a good machine. That's what I use here at my shop just not that particular model. In fact, it looks a little slow at only 14 impressions per minute. Which would suggest it may not be robust enough for a print-for-pay environment. Assuming you are just starting out and don't have a lot of money, it should be able to get you started. Canon, Konica Minolta, and Ricoh make some good machines as well so you should consider them as well if they are available in your area (Hong Kong I'm guessing?). The most important thing you could do is go try it out. Either visit a dealer's showroom or find someone that has one that would let you play with it. Second most important thing is to make sure the dealer you buy it from has good service and support. And of course, make sure the specifications are at a level you need for the products you want to produce.
I'm just using it at home for normal print jobs. Is it too much to use that printer?
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
