i normally get blank tabs delivered from an overseas supplier as we can't source them all locally. that supplier is not responding at the moment which got me thinking about whether we could cut our own tabs.
i looked at some options for tab cutters, including the JBI Onglematic 5.
jamesburn.com
Productivity is not that great at a claimed 500 tabs per hour.
I then was wondering if there is an improvised way of doing this? Some kind of cutting machine that can be adjusted to cut at set depths horizontally and vertically. I'm probably overthinking this.
Onglematic5 | JBI
O5 Standard Cutting width : 210mm / 8.5" & 297mm /11" O5 P Cutting width : up to 320mm / 12.5" O5 A3 Cutting width : up to 420mm / 16.5" Cutting thickness : 10 - 15 sheets (80gsm) Up to 500 dividers / hour Above output is based on…
