Text Creatoutline
You mean by applying to the whole document with one click, basically? There may be something in Pitstop Global Change as far as PDF editing goes. But I have always done it one page at a time or where needed.
You can really get fast at it in InDesign when you get the shortcut keys down and get into a rhythm.
You may want to try the following script, works here with a simple multipage document. Paste the following code Script Editor, compile then run. Carefully check the result though...
Got it from MacScripter
tell application "Adobe InDesign CS3"
activate
tell document 1
set text_to_outline to every text frame of it
create outlines of text_to_outline with delete original
end tell
end tell
