The initial position of plate&offset cylinders
egorus
How to correctly set initial position of plate & offset cylinders?
Variant 1, 2 or3?
If I understand you question, you want to ask the position of the image on plates.
Plate cylinder should be zeroed in circumferential and lateral direction and start of the image on plate depends on the type of the press and layout of the job.
I hope this helps.
