D
Deleted member 16349
Guest
Should the print industry be interested in the science behind the density control problem? The ITB addresses that problem.
Just a comment for those who are curious on the status of the ITB.
The ITB or Ink Transfer Blade, besides having a US patent (#6,857,366), has been allowed by the Canadian Intellectual Property Office and will be granted a Canadian patent shortly.
For those who do not know what the ITB is, here is a short explanation.
The existing ductor roller technology, which transfers the ink from the ink fountain roller to the roller train, is a mid 19th century technology and not much has improved it since then. This existing method of transferring ink to the roller train is inconsistent because ink transfer is affected by changes in water setting, press speed and roller train temperature. This then results in print density variation and "ink water balance" problems seen by the press operator when running an offset press.
The ITB fundamentally changes the ink transfer method by forcing the ink from the ink fountain roller to the press roller train. This action is independent of changes in water, press speed and the temperature of the roller train and the result is consistent solid print density with a much increased water window with respect to print density. With the ITB, the print can not be washed out by greatly increasing the water feed.
The advantage of the ITB is that it is a very low cost and effective solution to density control. Correcting the inconsistent ink feed problem in offset presses is a prerequisite to having a predictable press that can eventually have "hands off" control. With a press that is inherently consistent and predictable, expensive on line colour feedback systems would not be required.
The ITB is not a product. It has been tested on a few presses and confirms the theory. It is potentially a process control technology a press manufacturer could develop, if they really wanted a low cost solution.
The ITB also shows the true nature of the density control problem, ink water balance and predictability requirements on offset presses. It is not only a technical solution but a scientific solution. A scientific explanation of the problem should be of interest to all.
Edited by: Erik Nikkanen on Feb 10, 2008 1:20 PM
