Do any members have experience running heat sensitive otherwise know as thermo chromatic inks on a heat set offset press?. Thermo chromic ink is traditionally used in the security print industry (anti forging etc) and the food industry on flexo presses, I am looking at the possibility of running this on a heat set press with but then the heat and also the chills may damage the structure of the ink which is either a lueco dye or a crystal based dye so any advise, suggestions or experience you may have is welcome
sample
sample
