I-Zoom is now part of TIFF Pager
We are now beta testing the new I-Zoom export format out of our "TIFF Pager" application. This is an awesome capability added to an already awesome tool! Here is an example of an I-Zoom job made from 2400 DPI TIFF files for a 6 color job:
TIFF Pager Zoomable Proof
It has excellent color quality and smoothness of user experience.
TIFF Pager can create everything needed to post zoomable jobs to any web server. So now you can stop trying to send users a "Low Res PDF" and instead let them view all the way to the dot level. At $1595 TIFF Pager is a fraction of the cost of any other solution - and here are some of the features.....
- Supports up to 16 incoming TIFF files in either 1 bit screened or 8 bit contone format
From these incoming files it can CREATE...
1. PDF files at any resolution up to full res of incoming
2. JPEG image
3. EPS-DCS placeable format
4. I-Zoom format
For ALL of the formats it can then DO.....
1. Cut up TIFF files into any size pieces - as many pieces as you want
2. Rotate, and scale each piece
3. Allow you to export a map for cutting up files - in JDF
4. Allow you to import a map
5. Import JDF from Imposition programs
6. Deimposes signatures back to single page format with proper heads up of final pages
7. Properly applies page numbering of pages from an imposition
8. Create Color managable output PDF files
This tool is really the Swiss Knife of TIFF files and should be in the tool box of any printer.
OnTimeProof || Production workflows || TIFFPager
David Lewis
