A ganged one bit TIFF is the way I was suggesting, however there is a way to use a mask in Preps to cover the plate area then turn the plate around and image the second flat, I personally find this way far to clumsy but the customer wants it this way.Can you alias/map the ink in Preps from one plate to another?
If not, you could dupe the PDF and alias/map from one plate to the other plate using Acrobat Pro, PitStop Pro, PDF Workflow software such as Prinergy etc. That way both files have the same ink colour and you output only the required ink colour. Or the Workflow or RIP alias/maps or only outputs the required separation etc.
In the flexo world, separations are output to plate resolution 1-bit TIFF and Kodak TIFF Assembler Plus software is used to combine separations and jobs onto a single flexo plate, creating a ganged 1-bit TIFF for output… A similar approach could be taken in an offset environment using RIPed data rather than composite data and Preps, even if this is not the regular way to do things it is an option.
That sounds like the solution to this problem, gonna try this tomorrow.To burn only half a plate you will need to set up a new plate size that is half of the width of the plate you want to image. When you load the plate the Trendsetter only looks at the distance around the drum not across so it will load the plate and only expose the first half. We have been doing this for quite a while and it works great, much easier than trying to put 2 different seperations onto one imposition. You will probably need to create some new Preps templates. We also added a mark so they knew where to cut the plate.
