ultimate slitter and creaser?
wonderings
Our company got out of print a year and a bit ago and we have just gotten back into the game. So we have setup with all new equipment. I would like to automate as much cutting and finishing as possible so am thinking of a slitter that does creasing and perfing. Who makes the "ultimate" for this? I know Duplo but have no experience with them or any other slitters. If money was no object what would you get and why?
Our shop used the Duplo 618 for a good while but we found it was just too slow to keep up with our normal day to day production needs. We ended up re-selling it for the bigger 648 and it's a very reliable machine. If you're planning on finding a way to automate all cutting you're just not going to find it. These machines are great for specialty work that needs scoring/perfing/small runs. Other than that if you're looking for a way to cut everything at a reasonable pace really your best option is just a good ol' guillotine.
EDIT* I should mention that the perf tool isn't included in the 648 or 618 and needs to be purchased separately which usually isn't cheap
This is a really good point because the slitter/cutter/creasers (SCC) perform best with cardstock. Ideally, you should have both an SCC and a guillotine. You can get away with heavier-weight text paper in a SCC such as 100# gloss text, but even that can sometimes be problematic. If you get a programmable guillotine cutter, it can be much faster for many jobs. For instance, if you have a job that you just need to cut in half, or in quarters, you'll fly through it in less than half the time a SCC can do it, and the programming will make it automatically move the backstop in between cuts. Our cutter even tells the operator which way to rotate the stack next. The shop I work at now has an AeroCut SCC, which works fine, but we had a Duplo SCC at my last job, and I prefer that interface. The Duplo 648 is also really great for large amounts of business cards because it has an elevating stacker.
Depending on what you are doing, ultimate could be a die cutter:
That's what I was thinking. If it is standard items that don't change, a rotary die cutter is extremely fast and can do complex scores and perfs while cutting. Changeover is quick.
I bought a Duplo 618 last year. Absolutely love the machine. It suits us so well - we print a lot of NCR docket books, large format printing and business cards etc. There are days it’s not used (due to how busy/quiet we are) but when it gets going it’s amazing. Set it up and walk away!
My Ricoh Pro C7100 fiery isn’t compatible with the duplo imposition software, so I’ve been manually entering in all the measurements etc (total pain knowing the capabilities) but I know when it gets sorted it will be even more amazing 😉
Someone needs to make a machine that combines a rotary cutter with a slitter creaser like the DC-618. It would give you the best of both worlds.
I think the 618 rotary tool module comes with a slitter blade you can change out with the perf. But the 618 has so much more than the 616 had for a decent price
