UltraFlex Ultrapoplin S240 fabric on HP Latex 365
ThePrintPeasant
Hey all,
I'm wondering if anyone out there is currently printing on an HP Latex 365 (or similar) and using the UltraFlex UltraPoplin S240 coated fabric? I am trying to figure out if this material needs to be connected with the take-up reel before beginning the print, or if the material is able to be loaded and printed without waste.
A little backstory - we are currently printing on HP Light Fabric, which is pretty porous, so we are using the ink collector platen with the material. It is also very lightweight, so we have to advance the material and attach it to the take-up reel before we can start printing, because it needs to hold tension the entire time it's printing. This results in us losing probably 4'-5' of blank fabric material every time we load to print. I am looking to switch to a fabric that has a coating, so we don't need to use the ink collector platens, and also something that is heavy enough to hold its own weight as it runs through the printer, allowing us to just load and print without the extra waste.
Anyone run into the same issue? Do you have a latex-compatible fabric material that you swear by? We aren't printing table throws or anything, it's more like research posters for folks, as I work for a university print shop. People like to have the fabric posters so that they can fold them and put them into their luggage as they travel for conferences, etc.
Thanks in advance, and happy printing!
Craig
Try banner mesh and see if that would suffice. May be a little bulkier, but it has a removable liner and you wouldn't need the ink collector.
InSoft
Learn more..
