Uplan programming question.
Miskwissen
Hello!
I have a case where i need to pull multiple images based on different data in multiple fields from excel.
For example if I had 3 fields
Component|Letter#|Program
with different data
a|1|S
b|2|m
c|3|v
How would I direct it so it picked an image, based on the data that was in the individual field.
IE:
Pick
a|1|s
Any help would be greatly appreciated!!
Thanks!
What you want to do is create a variable. Open up the variable, and you can use qlingo there as you would with Adors. Use an IF or SWITCH statement from the Qlingo templates, and tell it:
If A
X
else
If B
Y
else
If C
Z
Where X Y and Z are the names of your images.
Now go into your image Ador: instead of using "|>ImageAdor" use "@{variable}"
Now your image ador will read as X, Y, or Z, depending on the logic you put in the variable.
Cheers,
JG
