Re: Vegetable Washes & Odour?
Well tried a wash from fluid technolgies - KV100 which is 100% veg based, and it works great, hardly any wash is needed to get the job done, and I have had none of the problems that I encounted with the Bio-3 wash, and to top it off there's nearly zero odure, so to anyone here in aus that has had limited success with veg based washes, give this one a trial, you will be amazed..
We are by no means a huge company but we have now managed to go from high VOC washes/solvents and high IPA levels to a 100% veg wash with near zero VOC's and with the use of Allstar Ultra fount solution cut our IPA usage by 80% from 10% dosage too 2% and soon too 0% with the use of lower shore hardness water rollers, and yes thats while using poly plates. I'm stoked as I now suffer no more chemical headaches, and no longer stink of chemicals at the end of shift
