Violet ctp preventive maintenance
sibikb
Dear all,
kindly give information about the periodical preventive maintenance of a violet ctp for its better life.. what all the activities should carried out during preventive maintenance ? which is good ,quarterly or biannual preventive maintenance ?. Right now we are using agfa violet ctp.
Thanks for your reply
periodical maintance
* clean the strips
* clean the lense with iso-propyl alchol
*clean the internal drum properly
*checking the input & output belts
*check whether the laser power is reducing if u think so
*calibrate if u think tat there is a loss or gain of dots
*maintain the room temp: properly which is important
"Right now we are using agfa violet ctp" - saying that you told us nothing.
Give us a little clue - model's name... just for beginning.
HI DEAR FRIENDS
my tesetter is agfa palladio 2003 ... and please Introduced me to all kinds of violet plates for this device
thank tou for your attention
It depends on maximum laser diode power of your machine.
5 mW: no choise - AGFA LAP-V.
Palladio CTP. I have a problem, get a spot along the plate, as if in that area the laser does not come with enough power. I checked the rule development process for processing failures Agfa LP86, all is well. What do you think is the cause of this failure?
We have a Heidelberg ProSetter running violet . .. . the biggest maintenance tip I can give you is KEEP THE PROCESSOR CLEAN after that keeping the filters in the ProSetter clean
The maintenance on our violet Agfa processor was messy nightmare. I am SO glad that about 2 years ago we switched to Kodak Thermal Direct plates, no processor to deal with, and the plates printer better than the Agfa LapV plates.
-Sev
There is a dust on the edges of facets, it's time to clean the spinner mirror - very common problem.
