The OP asked the same question in Feb 2020 citing a leasing budget of $2000 / month, I think this machine may be just a little over budgetWithout a doubt this is the one to get
I thought best to start high then work our way downThe OP asked the same question in Feb 2020 citing a leasing budget of $2000 / month, I think this machine may be just a little over budget![]()
You been living under a rock. This one is superior to all. And will set you back only $2 million or so I’m guessing.I thought best to start high then work our way down![]()
If you like scuffing on the folder, treating stocks, limited sheets sizes to run and non-existent service then by all means spend one million dollars on a huge boat anchor. We went with a Kodak Nexpress after tons of investigating and have never looked back. Margins increased by 28%.You been living under a rock. This one is superior to all. And will set you back only $2 million or so I’m guessing.
HP Indigo 100K Digital Press | Commercial Digital Printing Presses
The HP Indigo 100K Digital Press, the world's most productive B2 digital solution, is a general commercial digital printing press providing you with premium quality and colour for commercial printing brochures, postcards, booklets, newsletters and more.www.hp.com
Haha! I think the best option would be to get both. Just to have yourself covered.You been living under a rock. This one is superior to all. And will set you back only $2 million or so I’m guessing.
If this is a serious question. What is your application, your expected volume, and your budget?WHAT'S A GOOD DIGITAL PRESS TO BUY?
one you can get as much toner as you need for, whenever you need it...WHAT'S A GOOD DIGITAL PRESS TO BUY?
Depends on what works for your particular business model.Buy, not lease?
Helene, since you represent Landa, can you tell us what the true cost per page is for the S10? Is it any better price wide than the current toner machines out?One that supports your existing 40" offset environment with B1 format, will produce 96% of Pantone colors, is super-fast (6500 sph), and has all the versatility and variability you need for your future, and all of your database-driven print jobs.
Landa Digital Printing
(I represent Landa, happily, because this machine is just amazing. I still get chills.)
Thanks. Ive seen the press releases and the brochures. What I (and many others on here) want to know is what is the actual cost of a sheet. Since this isn't an offset press, we would naturally assume that it has a per sheet cost similar to a toner based machine. Sheet 1 cost the same as sheet 1000 and sheet 10000. So what is the "ink" cost per sheet is what we want to know.As you know, there are many variables – and keep in mind that there is no waste and very low-to-no makeready on Landa presses. However, who better to ask than a Landa customer? Here's what Paul Hudson said in a November (2021) press release:
The Landa S10P’s unique, expanded color gamut; better economics; and higher productivity made Hudson’s decision to choose the S10P press a straightforward one. The 7-color Landa S10P will reproduce 96% of Pantone colors.
“The S10P checked all of our boxes,” Paul Hudson says. “We needed the speed, the B1 format, and the best color available. Over time it became clear that Landa’s advantages are better by orders of magnitude.”
Later on, he says: “We have some large direct mail jobs that can take dozens to even hundreds of hours on digital presses,” he says, “but when you move over to the Landa you not only have a much larger sheet size with B1 (41”); you also have much faster production speeds and coating inline.
“It’s a fantastic productivity tool for direct mail.”
The full press release is here: Hudson Printing is Home to a New Landa S10P Printing Press - Landa Nanography
"I'd like to know the approximate cost per sheet to print using your press"Thanks. Ive seen the press releases and the brochures. What I (and many others on here) want to know is what is the actual cost of a sheet. Since this isn't an offset press, we would naturally assume that it has a per sheet cost similar to a toner based machine. Sheet 1 cost the same as sheet 1000 and sheet 10000. So what is the "ink" cost per sheet is what we want to know.
To spell it out simply. Those of us with regular toner machines pay a click of $.04 give or take per side on a 12x18 sheet for full color. Since you could get 4 up on a B1 sheet that the S10 prints, would there be significant savings in ink/toner cost over a standard press? Or are you making up the cost with productivity in its print speed and make ready? Although every digital machine has a first sheet make ready.
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
