prepress labels
Hello!
Our Epson WT7900 proofer (six years old this month) is clogging in about 1/3 of the yellow nozzles, and no amount of cleaning/power cleaning/physical cleaning has fixed it so far. Here's what we've done:
1. Run cleanings or power cleanings: these usually result in a "Cleaning Error: Retry?" message.
2. Replace the low yellow cartridge. Didn't help.
3. Open the door to the proofer, go into service mode to free up the print head so it slides freely, & clean out the flushing box, underneath the print head, etc., with paper towels & isopropyl alcohol (following a video on YouTube). Didn't help with the yellow (we did get a lot of ink cleaned out though).
We know this proofer is way past its support, and I've seen postings of similar issues before. We've also upgraded to a new Epson and use it for our white substrate proofs, only using the WT7900 for white ink on clear, varnish overlays & the like. All other colors except yellow are working fine at the moment.
Does anyone have any further ideas we can try? The white ink itself is still functional, but when that goes, we won't be able to produce true white-ink proofs anymore. We're worried that the yellow might be the "canary in the coal mine," and that the day is coming when the white gives out permanently.
If we can't fix it, what alternatives are there? We've brainstormed:
1. Buy another used WT7900: it may come with the same mileage and/or print issues we have now.
2. Look for a new proofer that produces true white ink: we've only found one option, for about $50,000.
Any other options? Thanks for any input!
