kanovits
Good evening,
We have installed a Xerox 1000 Press in July 2013, and started with awesome print results.. till september. Our problems started with 1mm +/- registration problems, then with unpredictable artefacts on pages (something like strong JPG compression artefacts visible on all solids), toner fixation problems on heavy stock (300 & 350g, white spots with missing toner particles everywhere). Tech staff adviced to set manually the fuser temp to maximum +10, but after another weeks it was not enough to print on 300g stock with setting of 350g and fuser temp max... While after the installation we printed superb results with default fuser temperatures.. Tech staff first said that we have bad paper, but another X1000 at neighbor printer service printed to our stock with perfect result. In meantime the quality of our prints are worse and worse, with strong visible repeated banding, bad toner fixation at the edge of sheet, bad registration between two printed color strips (like when we must to use trapping, white band between two colors, but in this case enabling trapping not helps). Tech staff serviced the machine for 2 weeks, replaced drums, fuser belt, registration motors... The result is much better overall print quality, but the strong banding and coloration effect is still visible, toner fixation at the edge still problematic. Xerox yet sent us a statement, that these effects are normal and this is not offset quality machine... Welcome any advice. Thanks.
