Greglorious
So, I almost don't know where to begin.
For starters, I don't believe that I'm experiencing a software issue. I read in another Thread that a corrupt mail box could be causing the issue.. so, I've checked the status of the mail folder (via fiery configuration: Clear Each Scan Job) and it appears to have the correct (manually) settings.
I've read that you can determine the communication between the rip and the 240 by simply clicking the "refresh templates" button under "network scanning" on the 240. I tried this and it failed to refresh ever time.
I've also read of the crossover cable could be the root of the error.. so I made sure that it was in place (and even replaced it with a new one.)
Even after all of this, I'm still having the issue.
A Xerox tech suggested that it might be an issue with the SCSI cable on the back.. but I' unsure of rather or not that's what's doing it. Could this be it? Might it, instead, have something to do with network settings? The machine does appear to be sending and receiving info from the printer (oddly enough)...
Now, the scanner still works.. It makes copies and will even scan a document.. it doesn't error out until it attempts to "transfer" the file to the mailbox.
What gives? Any help would be appreciated..
~GB
~GB
