Xerox 8160
Xerox 8160 is an enhancement of the Xerox wide format printers. The following are the benefits you might want to consider:
 Time and paper efficiency- Xerox’s wide format color server drives images to 8160 to give preview color changes prior to printing, that help save time and conserve paper
 Allow users to rotate and position images for optimize paper usage
 Enables operators to save job settings for later use
 Supports easy integration of existing wide-format machines
 Improved color accuracy by preprogrammed profiles
For more details you can check application and user guides for 8160
mjlake, thanks for information, will consider it before buying. Any idea what Xerox 8160 is worth at the moment.
