XMF & latest version of Illustrator
Topcat00
Hi, I received 7 pdf files with common backs (created from Illustrator 27.9). I dropped them into XMF as I usually do.
Check the correct size of each in the run down and they all look like the first file????
Re saved all the pdf's, same thing. Opened the pdf's in Illustrator and saw that there were layers for each different version.
XMF was only seeing the first version even though is was turned off on the other 6 versions.
The only way around was to either open up all the pdf's and deleted the versions that were not in use or I dropped the pdf's in InDesign.
Dropping them into InDesign worked, but I have never had this problem before with earlier versions on Illustrator.
Just wondering if anyone else has had this problem.
LMK
Thanks!
