SEATTLE, Washington, Nov 21, 2023–XFCut Software, announces XFCut 6, a major upgrade to its best-in-class vinyl cutting desktop software plug-in for Windows and Mac OS X. And for the first time ever, XFCut is now available for CorelDRAW (Windows only) and Adobe Illustrator (Windows and macOS), With intuitive user interface, one-click options and advanced sign tools.
XFCut is a vinyl cutting plug-in designed to work for sign makers currently using a desktop design application, like Adobe Illustrator or CorelDraw. It allows you to automatically add registration marks into designs, create contour for printing and cutting jobs, create cutting data and send cut jobs directly from Adobe Illustrator or CorelDraw to your vinyl cutter and cutting plotter. No need to export/import files between design and production applications.
XFCut supports almost all common vinyl cutters and cutting plotters from various manufacturers, including Mimaki, Vinyl Express, USCutter, UKCutter, GCC, Graphtec, Roland, Secabo, Vevor, Saga, Rabbit, DGI, E-Cut, Jinka, Refine, Yinghe, JiaChen, Liyu, Redail, Summa, Mutoh, Houston, PCUT, Mycut, Vicsign, Desay Master, Seiki, Signkey, SkyCut, Pixmax, Cutok, ANAgraph, KNK, Ioline, and others.
XFCut 6 highlights:
To learn more about XFCut v6, and to download a free demo version, visit Vinyl Cutting Plugin software for CorelDRAW/Adobe Illustrator .
XFCut 6 highlights:
- Compatible with the latest versions of Adobe Illustrator (Windows and macOS).
- All popular vinyl cutting plotters are supported (700+).
- Compatible with the latest versions of CorelDRAW (Windows only).
- Complete, efficient print and cut workflow.
- Support of cutter's optical alignment methods to guarantee precise contour cutting around pre-printed graphics.
- Support of the TCP/IP protocol to communicate with the cutter.
- Set cutter speed and pressure.
- Add registration marks to your design for print and cut workflow.
- Weld overlapping objects and text.
- Cut of entire job or selected elements.
- Automated, precise contour cut interface.
- Automatic detection of optical alignment methods’ registration marks.
- Multiple job queue.
- Corel DRAW direct workflow plug-ins.
- 64 bit speed.
- macOS 14 and Apple Silicon fully supported.
