Hi ondagawood - just out of curiosity, what would be the advantage of trying to recreate Pantones using 7 non pantone inks? I mean - with 7 Pantones, you have quite a lot of colours to play with, instead of having to use 7 "process" colours?
Just curious - I am sure there is a valid reason for this. Cheers!
Here are some reasons why an extended process color workflow is used instead of spot colors:
• More efficient press utilization/smaller (less expensive) presses
• Greater efficiency via simpler combo sheets/maximize sheet usage/minimize wastage
• Virtual elimination of makeready (and associated costs)
• Provide more creative options because design is not limited by the number of spot colors that can be used
• Brings long run cost efficiencies to short runs enabling more marketing options (e.g. localization)
• Enables just in type inventory fulfillment
• Align color across various printing methods or media
• Simulate arbitrary colors
• Create aligned real world-to-print color recipes
• Create cross-printer “safe” colors where printing is done at multiple locations
• Extended gamut also available for contone images
Depending on the needs of the print buyer/and packaging needs any one or multiple value propositions may be sufficient reason to implement such a workflow.
best, gordo
