7mil film on Dolev800V2
Repro_Pro
Currently we run the regular (4mil thickness=0.1mm) film very reliably.
We may need to image thicker 7mil (0.18mm) film for its' better dimensional stability.
The machine specifications allow for this, but I would really like to know if anyone has actually done/doing this.
Should we expect problems in film transport (load/unload) or in photographic quality?
TIA
Yes I have some custome use film 7 mil on Dolev800v. It's working fine no loadding problem. You need to set thickness in media info from 4 mils to 7 mils
Thank you, this is good news.
I was especially concerned about film behavior at the end of each roll, when the stronger curl of this thicker film may cause problems along its' way.
