heraldnews
We recently picked up an AB Dick 360, which is supposed to print 11x17. Is there something special you have to do to get it to print on that size paper? The suckers keep grabbing the tail end of the sheet.
I don't know much about AB Dicks but it sounds like the timing is out. You may be feeding the sheet in out of time, and getting away with it but then the suckers come down and grab the tail end of the sheet. If it has a hand crank see if you can feed the sheets through manually via the crank handle with the suction on and check the sheet travel. Just a guess but check it out.
