doctorsax13
Hi all,
I'm up a creek right now.
I have an 8805, similar to a 360 -- it has been running fine for the last year and then suddenly on friday lost the ability to make impression. As in, the timing of the feed is fine, and it will feed the paper through, BUT doesn't realize that it's feeding, so that it doesn't click the counter or bring the cylinders together to you know, make a print.
After some exploratory surgery, I have found that the mechanism triggered from the egg-shaped cam on the non-operative side of the blanket cylinder that triggers the count-click and the impression is seemingly out of time with the concave cam on the operative side of the blanket cylinder -- which is confusing to me because 1) there's no reason why that would all of a sudden go out of time and 2) those two cams are mostly independent of each other anyway, and change relative to each other when adjusting the vertical registration.
Does this make any kind of sense, and has anybody ever had this kind of issue with a 1-color AB Dick? There is no apparent electronic sensor to detect the paper, and honestly, I realized that I never did figure out how it KNOWS that paper's being fed through to impression.
Help please. I'll give you a cookie.
Chris
Chris
