Accuset 1400 - black is not black enough
lkavan
Hallo Friends,
finally, I am able to print on my Accuset. I have used Appletalk drivers from WIN2K and Adobe Illustrator 8.0, all at Win XP. Nice, that works! I need to make films for PCB samples production, so I need full white and full black only. But unfortunatelly, I am not able to get the black dark enough. The piece of film, which is always out of casette and it is on daylight, this part is always black as the hell, but black areas, which are lighted by machine, they are much more light. I have set density to 255 on machine's menu, I also bought new chemicals to process the film and still it is not black enough. Do you have some idea what to change? Is it possible, there is some dust at optical way nad optical power is not enough? Can be laser to old with low power?
BartS
Have you checked the developer temperature and time? What kind of film you use. My Agfa HNS film has a max. density of D4.2 with ACD developer.
Cleaning the optics of the imagesetter is important but shouldn't make a big difference in density. I don't know how to check the laser power.
Willett
Hallo Friends,
Hi There.
Couple of things to look out for with density.
Make sure you are adjusting the density for the resolution you are printing at.
1200dpi will be a different setting to 2400dpi. I think you can run an internal test page that will produce stepped density pattern so that you can pick the correct value.
What rip are you using? density might also be set there also
If all else fails you might have to remove the laser optics unit at the bottom of the machine and clean the spin motor mirror.
Hope this helps
lkavan
Hi There.
Hallo Willett,
thanx for answer. Yes, I know, that density settings is different for each resolution, I have checked this.
This I have made, black is still not enough when I have set density to max. - 255
It has internal Star RIP.
Hope this helps
Thanx, I think, optics cleaning can be good step. Is it too complicated? Can I destroy something?
ChrisZ
Take a piece of film, expose to sunlight, than run through processor and check black density.
lkavan
Yes, this I have made. When I remove casette from machine, cca. 5cm piece of film is out from casette and exposed to the daylight. This part of film is always total black, but image from Accuset is not so nice black. I tried different processing times, temperatures etc. but result is always the same - daylight exposed film part is nice black, image is lighter :-(
Repro_Pro
Look if you can find a filter in the beam path.
If you find one - try to remove it an expose a test film.
maxon
Check emulsion side.
Check roll year of manufacture or 'best before' stamp on label, the film may be old. Replace with a different batch.
InSoft
Learn more..
