Agfa ProSet 9550 / 9800 HELP !
Darin
Can anyone out there help me with a film feed problem. It will load and tension but not feed. You can hear a small hum not the louder hum that it usually does when feeding.
This is of medium difficulty to fix. Remove the film delivery part where the paper is trimmed. Remove the front top cover where the film return button is. remove the cover on the back side. Look down and the are 2 screws on the front (where the belt is) and back side of the delivery unit. The screws are fairly deep into the machine. Remove the 4 screws and lift the film delivery unit up and out. Then you can see the rollers. There is probably a small piece of film lodged. Be careful with the wiring.
