Anicolour squeaks!
BigE1968
Can anyone help with a problem on our Heidelberg Anicolor SM52.
we have had in installed second hand and we have a problem with squeaking coming from the black and yellow units. It appears to be connected to the ink chambers. If we take the chamber out and re-insert it goes away but soon come back. Have any of you lovely printers experienced this?
wyagow
I run the same press and have had the same issue you stated on rare occasions. It could be several things. Check to make sure chamber blade is installed and seated correctly. Watermark on blade facing the anilox roller. Replace chamber felts and lubricate with roller lube. Double check that anilox roller bearing is locked properly. These are just a few things you can try. If I think of anything else I'll let you know.
