Aqueous Coating Cracks
aqazi81
Hi All,
We are facing issue with coating cracks on heavier coverage areas. Low coverage areas have no issue or very little visible.
Please view the attached images of the issue.
Here's a couple of troubleshooting guides the answer may be in there somewhere
https://www.fujifilmusa.com/shared/bin/TroubleshootAC.pdf
https://www.fujifilmusa.com/shared/bin/AqueousCoatingGuide.pdf
https://printplanet.com/forum/press-technology/sheetfed-web-offset-discussion/9530-aqueous-coatings
The best answer seems to come right from this forum mud cracking", the coating is drying too fast on top of a heavy build.
Make sure the coating is at least 20 seconds (Zahn#3)
Turn the IR's down, along with the hot air knives
Speed up the press
Increase amount of coating (if you have an adjustible coating system)
Good luck
Hello aqazi81
The problem you see is - Reticulation, trying to overprint Printing Ink with a Water based fluid is not a good idea.
Yes - I know Aqueous OP are widely used, Think- Surface Tension Problem
Regards, Alois
Mud Cracking.
The coating is drying faster than the ink underneath. As the coating is applied to the film of ink(s) underneath, it's crawling giving the 'Alligator Skin' look. Talk to your coating suppliers about a slightly slower drying coating.
Have you done a AQ coating weight test?
What BCM roller are you running?
Do all your different coating types have the same issue?
CKL - Good points. If he's running a roller coater, than BCM is irrelevant. He can certainly check his coating stripe and measure viscosity using a Zahn #3.
Aqazi - Is this happening with Gloss, Satin, or Matte? Or all coatings?
