Switched to Azura Vi from N91V four months ago, no problems. Quality is good, not fabulous, but the platesetter must play a role here I'm talking about an 8-year old Mako 2 with barely 18-ish micron laser spot size at 2540, perhaps modern platesetters produce finer images on Azura Vi. Do calibrate the laser intensity, the plate requires more energy. Be very careful to use the improved cleaning gum, labeled as 'improved', do not use the regular CF-Gum it DOESN'T work. Before converting your plate processor to Azura Vi, clean it like never before. PM me for more info if you want. Auguri.
