Back again for help...create bleed
steppy
We need to add bleed to header of pages generated from MS Word.
Using the add bleed action without FIRST defining all page boxes gives no bleed.
With page boxes defined, action consistently gives bleed on two of the three sides of the header.
Headers in Word are raster images.
I've attached:
  • original pdf
  • pdf after action but no page box adjustment
  • pdf after page box adjustment and bleed action.
  • the actions used (ZIP).
APPRECIATE any help/ideas.
stephen
I think something is not right with that PDF, it does not react properly to actions (PDF Producer is blank).
I made you new action that forces trim box and resizes other boxes, than add bleed and crop marks, it works on my end.
I hope this helps
I have never had any luck adding bleed on files from either Word or Publisher using the default action lists.
Files from Indesign or Illustrator generally work flawlessly
Might be an idea to add a specific Action for Office based files.
We have a preflight profile specifically for Office files that adds bleed, but it does a lot more such as overprint and color conversions.
You'll find that at Generic Enfocus Preflight Profile > Just make my Office PDF work! - CMYK ISO Coated v2
I'll take a look at adding a bleed action for Office in the next release.
@steppy you might want to get involved with these workshops. It's a perfect place for questions like these.
I hope this helps
Zoran:
Thank you! Unfortunately we don't have latest PitStop, (still on 13) and when we try your action we get error. (see attachments).
After opening (and I guess removing the incompatible portions) we get the same result as prior.
Agreed, something is wrong with the pdf!!!! Supplied by client unwilling to try any pdf creation suggestions; need we say more?
Appreciate your effort.
stephen
Can you add the bleeds to the PDF in a raster program like Photoshop? (I use edit>fill>content aware)
Thank you Andrew!
Just make my Office PDF work! almost worked!
Three of the four pages now have bleed and one does not, (see attached). Puzzling.
Appreciate your assistance.
stephen
Unfortunately there are way too many to start rasterizing. Text would not look great also.
UPDATE
We looked at the pages that did add bleed working with "Just make my Office PDF work!" and when compared to the one page that did not, found that the position of the image was different, (we're talking thousandths of inch mind you).
We wrote an action to select image and adjust to the same position as the pages that worked. Running "Just make my Office PDF work!" after this then worked on all pages.
Maybe not the most elegant but it worked.
Thanks again for the feedback.
stephen
You can also try with FreeFlow Core available for free download for 45 days.
Or you can try with Callas pdf toolbox .. Callas pdf process plan may be if some help.
Thank you Andrew!
stephen
It's the value in the Add Bleed Action you probably need to adjust, it probably doesn't quite reach the trim, so you just need to adjust the numbers a little.
Nothing unusual, just a bit of training needed. :)
You can always drop me a mail. [email protected]
Happy to help.
