Baum Cutter 31.5e
gtmo
Hello,
We have a Baum Cutter 31.5e purchased brand new and it has been a "Lemon" since day one.
Curios to know if other people have experience problems with their Baum Cutter and what those have been.
Thank you in advance!
Hello Chock,
Thanks for asking. The problem we have is you can not see the screen most of the times, if we are lucky it can still be used manually. We have gotten over the years all kinds of codes.
The main board has been replace twice in the almost 5 years that we have had it. Yesterday it did a new one, the air went on without anyone using it.
It has a life of its own, as you are cutting the screen keeps resetting and much more....
Dear Sir:
I can understand very well:
Please do the following Test:
1) Using the Schematic Diagram measure in the backlight of LCD of Display: 350Vca, From connector X 517.
2) Measure in the connector X500:+5Vdc. This voltage can be in tolerance Not higer from 0.7% or down, otherwise Repair or replace Power supply from +5Vdc.
3) in all connector, see if there dirty, loose, corroded, or loose pins: Repair or Replace.
4) By other side please resolder the keyboard board for : Dry +Cold solder Joints ( attached is there the examples)
Let me know.
Blessing
[email protected]
