Bid Specs
printerdw
Hi there we are in the market for a new 4 color press and this is how we are going to spec it out can any of you think of anythig we should add or take out. thanks for the help
1. Local support distributor employed certified technicians
2. Two years manufacturer’s parts warranty backed by the manufacturer which is in addition to any labor coverage provided by the local distributor
3. Landscape 14 x 20” offset press
4. Semi-automatic plate loaders with plate clamping device with automatic plate cylinder positioning for plate change without tools
5. Bearer-to-Bearer construction. The plate and blanket cylinders each have bearers built into the cylinders. This design ensures that the finest of screen rulings and the hardest of dots may be printed easily and consistently.
6. Stream Feeder
7. Suction tape feeder board
8. Mechanical and electronic double-sheet detectors to protect the press from doubling and crashing
9. Pull Guide
10. Swing Gripper
11. 4 Ink Form Rollers (per unit) as required for all commercial printing presses for proper ink coverage and quality printing
12. Ink roller wash up function
13. Blank cylinder wash up with AQMD approved low VOC cleaning cloths
14. Full Press Console including:
a. Remotely control ink keys from the console
b. Integrated Touch Screen LCD Monitor
c. Display of all print functions and error messages
d. Washing programs which can be adjusted individually
e. Internal Job Memory (5+ Gigabits of Memory Storage)
f. Ethernet, USB, or Floppy Disk file transfer
g. Intelligent pre and post dampening programming
h. Remote control of circumferential, lateral, and diagonal register
15. “Smart” program inking to reduce make-ready time and ink waste
16. Scanning Densitometer is console mounted and integrated to communicate to the press computer and automatically calculate the values needed to correct color densities on the press
17. CIP 3 compatible
18. Automatic centralized lubrication system which does not allow for used/filtered oil to ever re-enter the lubrication system. Only new oil lubricates the press gears, bearings, etc. to prevent system contamination and possible unnecessary damage or wear
19. IR Dryer
20. Powder spray system
21. Tools, and required startup supplies to properly print four-color work
