The Volume of a Bit and the Depth of a Gamut
Interesting Subject and I can never resist trying to visualize these concepts so that I better understand them. There are a few concepts explained in the post that are very good, so I thought I would try to add my two sense worth.
I have been intrigued with Gamut Volume for years, and although I think I get it, I don't get it to the point to explain it as well as I want to so here goes:
The original request:
Could some one explain this in lay person's terms?
Assume we're editing images in PShop.
The ProPhoto profile has a larger gamut (more colors) than the Adobe 1998 RGB profile.
But you're editing the image at a bit depth of 8 bits per channel - i.e. 24 bit RGB.
How does gamut relate to bit depth?
thx, gordo
Gamut is like a container (the accordion fully expanded )
Gamut Volume is like how many particles fill the container
Bit would be the description "particle"
Bit Depth would be the amount of different possibilities for describing the characteristics of the individual particles
Now comes the interesting part:
Assume that we have two Identically Sized (gamuts) accordions that can hold 1 liter total volume when fully expanded.
One accordion has 100 pleats (lower bit depth) and one has 1000 pleats. (higher bit depth)
And let's also assume that the particles that we put into the containers are different sizes, (different Gamut Volumes) let's say one is filled with mililiter sized particles and one is filled with centiliter sized particles. OK, so one gamut holds 1000 particles and the other holds 100 particles. Easy enough.
So now each container could hold an equal amount of particles, and also has the ability to describe each particle that is contained in it. Even the lower Bit Depth has the ability to describe all of the possible colors in the gamut with the higher volume, or even the colors of a larger gamut for that matter.
So, in the end - Gamut and Bit Depth do not (practically) affect one another at all. The only time there would be an issue would be if you manipulate an image in a smaller color space and then convert it to a larger color space, but in my opinion that is 100% to do with the gamut and has little to do with the bit depth.
The importance of Bit depth is immediately and drastically recognized when manipulating Images. Take two identical images (the Raw Capture and the Raw Capture converted to Jpeg) and then try and fix a bad exposure, or perform any sort of significant modification. The JPEG has maybe 1/10th of the latitude of the Raw Image.
Well, that was my feeble attempt at a description.
CK
