Blister Cardboard Packaging
Azim
Hi there!
Do you have any experience to make the Blister cardboard packaging, printing on an offset press and adhesive coatings to plastic? What process did you achieve good results?
Does it have any specific paper, ink or adhesive glue to heat seal?
Thank you
Folding carton packaging often uses Blister seal adhesive coatings.
Usually done on SBS board, regular or UV inks.
Most important factor is the coating weight, best applied by anilox roll.
Coating adhesion should be tested in QC lab, under standard temperature, time, pressure.
Steve Suffoletto
