VladCanada
If you read this thread, did you pay attention at a message about null-modem cable?
That's the answer.
That's the answer.
Please, I need help with avantra 25 Offline imagesetter:
while booting it display error 43
With this error the imagesetter don´t put on Line or load film
Original control Panel (OCP) was replaced by a Control panel of a 44 Avantra.
I try download OCP User parameters but the donwload is´n complete (APIS Command failed and Error Location 15).
need I load OCP FlashRom Firmware to avantra 25 offline? can you send me it?
here are the dates
DEC Firmware 6.40
DSP Firmware A6.0C
OCP Firmware(OCP flashRom) 44.24
OCP Download(OCP EEPROM) 1.5
Diagnostic Firmware(C9) 10.16
Correction table 1.01-3
Brig/OLP n/a
Please, send me your help ASAP
Best regards
And what is the mining of these messages.Thanks in advance.
Really?
So, what's the reason for all Avantra types OCP to have the same partnumber in my AGFA Spare parts database?
here are the dates
DEC Firmware 6.40
DSP Firmware A6.0C
Brig/OLP n/a
Best regards
Rellay! Do you have the updated List? They do not work. If it does , then why do not you help the Guy?
Feb 2009
TX+002525-0570 All models
1. 'cause you stepped forward first, and I have no intention to compete you, Farshad
2. 'cause that's a real Professional Service issue and can not be done for free at open forum.
here are the dates
DEC Firmware 6.40
DSP Firmware A6.0C
Brig/OLP n/a
Best regards
I tell you one more time, Farshad - there are NO Avantra 44 or Avantra 25 OCPs !!!
That's the same box for all Avantras.
By default you will get from AGFA/UPS warehouse OCP preprogrammed for Av25 even if you ordered it for Av44. Your task, as FSE, - to reprogramm OCP for Av44.
I'm not an idiot ,and I do not need to be treated that way, Farshad!
Many times, without problems, using "back door" procedure and some tricks with C9 (C9A) Diag chip.Have you ever tried to down load the firmwares on the field as explained?
many times, without problems, using "back door" procedure and some tricks with c9 (c9a) diag chip.
Test passed![]()
