Calculating spine width for perfect bound books
QualityPrint
I am just wondering how others calculate the spine width for perfect bound books for a variety of paper types. We are coming up short on jobs using our current calculations especially on dull stocks. Any help is appreciated
What can catch you out is if you have the incorrect caliper input in your calculation software. There's a big variation in thickness on the same weight book wove between mills and paper types and the same is true for coated grades. Getting the caliper out to check would be my first step.
We always make a dummy with the correct stock before making the final adjustment. The kind of cover and the binding equipment seem to make a little difference too.
Regarding the Spine Calculator: What unit of measurement does it use? I get a number, but I don't know if it's picas, points, centimeters, inches, etc. :)
The spine should be:
(number of pages ÷ 4) x caliper
As Lukas said, though, your best bet is to make a dummy.
This gives a very good idea of spine size although you can get problems when some paper stocks are thicker than the norm for that weight etc. but 99% of the time its very close.
Text Pages
x
Paper Weight
x4
x25.4
divided by 200,000
