Canon V900 frequently pausing while "adjustment" is being made
Snowhugger
Canon V900 Printing jobs are frequently pausing while "adjustment" is being made, the fuser temperature I think. This is now happening more frequently than I remember.
I printed a black & white book on 50# offset, 107 sheets per book this weekend. It is a reprint job we have done many times. The printer is pausing approximately 4 times per book, every 25 - 30 sheets to "adjust".
I have fixed this issue in the past by changing the gsm (paper weight) of the paper description and the performance usually improves. I made several changes to the gsm of the paper description but the printer still pauses to adjust for a minute or more every 25 sheets or so.
We had a Canon tech in here to look at it and I ran one of these books to show him what I'm seeing. It acted just as I described above. He told me the machine is running normally, it is pausing to cool down etc. To maintain proper temp etc. The tech said I should pursue this issue with phone support from Canon USA, so I am doing that but just thought I'd ask here too.
Does anyone out there have a Canon ImagePress that is pausing to adjust too often? Is playing around with gsm settings a solution that makes sense to you?
Thank You!
Thank You!
if the tech said is true, put a fan behind the machine to help cool down the fuser to see if any improvements
Our old Imagepress C750 does this too. I think it's because it's a light production machine. It constantly stops for "adjusting". The higher end models have better fusing units and they maintain their temperatures better.
External environment affects this is the room colder that in the summer maybe the fuser is coming back up to temp? I believe all lasers do this to some extent and just lowering the gsm isn't always the answer match the paper to the proper settings. I think that line of copiers has an advanced setting that can be extended for less frequent adjustments but its been awhile since I've tried or asked. I have a custom paper saved for my 750 to do this for cheap down and dirty #10 env. use it for black corner copy never have had an issue.
It's been years since I had the C810 here, but there was a service setting to extend this "adjusting" from the every 30 sheets to a higher page count. They told me it could affect quality but I never did see that happen. Not sure if it will work on the V900 but worth asking.
are you certain it is all BW and there's not a sheet with a colour element sneaking in at p.25? don't know how it is on Canons but on our Ricoh C5310s the colour fusers will switch off after X amount of black only pages, and switching back on/off again entails a delay.
