I think there may be some confusion between 95-63-6 and 71-43-2. Trimethylbenzene is not benzene. It will contain trace (parts per million) amounts of benzene, as it is refined from the same distillation cut benzene is. A product that contains less than one percent of 95-63-6 will contain less than one percent of whatever parts per million trimethylbenzene contains or some number of parts per ten-million of benzine. It is a mistake to consider any of the three commercially available trimethylbenzene products as being in the same category as a threat to health as benzene. Remember, gasoline contains more than 7% benzene.
Dan,
You mentioned two CAS#'s:
First: 71-43-2
This is benzene it is listed in the following
RCRA, CERCLA Haz Substance, SARA Toxic Release Chemical, HAP, OSHA, IARC, NTP Carcinogen, 1pp TWA (means 1 ppm in a cubic vol of air over 8 hrs max exposure),
CA Prop 65 listed, CA Hz Sub listed, Delaware listed, Idaho listed, Illinois listed, Maine listed, Mass listed, Michigan listed, Minnesota listed, New Jersey listed, New York listed, North Carolina listed, Pennsylvania listed, and Washington listed.
CAS#95-63-6 is 1,2,4-Trimethyl benzene listed:
SARA Toxic Release Chemical, 25 ppm TWA (very low ppm),
Delaware listed, Illinois listed, Maine listed, Massachusetts listed, Pennsylvania listed, New Jersey listed.
AND, 1,2,4-Trimethyl benzene deteriorates hoses, seals, and roller compounds. AND it stinks. So why use either as an ingredient?.
